4 point harness.
Old Feb 19, 2003 | 02:27 PM
Shadohh's Avatar
Default 4 point harness.
Been thinking about 4 point harness today.
Now...general...you lose the back seats since you have to run them back.
but cant you loop them over the seats shoulder and down to the rear bolts holding the seats in.
Then loop the bottom ones down to the front seat bolts, or back the rear again.
I am guessing. its putting alot of stress on those bolts.
Has any come up with an idea to have a 4 point harness and not lose your back seat?
Or some sort quick connect/disconnect feature.
So when you its not auto-x weekend you can remove them for passengers.
Old Feb 19, 2003 | 02:49 PM
Viper966's Avatar
running a 4 pt harnass on a car without a roll cage can kill you if u roll the car.... just a FYI
u can just fold ur seats down.. there are anchors in ur trunk and use those for ur shoulders...
[ February 19, 2003, 09:50 PM: Message edited by: Viper966 ]
Old Feb 19, 2003 | 09:03 PM
Curtas's Avatar
Viper,
not questioning your accuracy, but just curious . . .
How would it kill you? I would figure it would hold you in better than a regular lap/shoulder belt.
just wondering,
ac
Old Feb 19, 2003 | 09:29 PM
Bat Lord's Avatar
Vehicle: Ex Hyundai Owner
I must say, I'm also confused by that comment... I think this is a rumor that's been passed down for a while now... but explain how a stock belt is better than a 4 point harness...
Old Feb 20, 2003 | 01:24 PM
BlueGT's Avatar
Vehicle: 2004 Tiburon GT
Nope, this is real.
Don't get those harnesses unless you have a roll cage and are planning to drive high speeds. If it's just for occasional auto-x and then you remove it for streets, then it's okay.
This is what I've heard. If you roll over with a harness and no rollcage your spine will get crushed in the seat. If you roll over with a regular seatbelt, you can squish down some so you won't get hurt as much.
If you do decide to get 4-point, I suggest Schroth Rallye harness. They are street legal (DOT approved).
Old Feb 20, 2003 | 01:49 PM
Bat Lord's Avatar
well knock on wood, but I don't see me rolling over anytime soon...
Old Feb 20, 2003 | 02:14 PM
blue2000's Avatar
Vehicle: 2K Tib
Shaddoh, there is at least 1 company (Schroth) that makes bolt in harnesses that have a quick disconnect for the shoulder belts so you can easily remove them when not autocrossing. Running the harness down to the floor is a bad idea, in even a minor accident the restraint of forward motion is leveraged into downward force, enough to compress your spine. Using the truck mounts is a good idea if you can find a harness long enough to reach them.
On the harness with no rollcage thing...The danger is because if your roll the car with no cage, the roof can collapse inward. Where a stock seatbelt will allow you to tip sideways or slide downward slightly, a 4 point harness does not allow you to move, thus your head or spine is crushed.
Old Feb 24, 2003 | 03:44 AM
RedShark's Avatar
Bat Lord:
lol exactly what i was thinking...
Old Feb 24, 2003 | 03:49 AM
RedShark's Avatar
hey yuri, what type of harness do you have?
Old Feb 24, 2003 | 04:06 AM
Bat Lord's Avatar
these:
and unfortunately, or fortunately, whichever you think, because of these harnesses, I had to redo my AMP SETUP completely, but trust me you will all like it 10x's better... smile.gif to those that have seen the beginning project, what do you think???
