2 vs 4 preamp outputs
Old Jun 3, 2014 | 05:22 PM
CodeKane's Avatar
Vehicle: 2005 Tiburon
Default 2 vs 4 preamp outputs
What is the difference between having a head unit with 2 preamp outputs vs 4? I'm running the head unit to a 4 channel amp if that matters.
Old Jun 3, 2014 | 09:04 PM
4 makes it easier to run 2 amps
so if you plan on ever running a designated subwoofer amp on top of a 4 channel amp for the mids and highs, then get a 4 preamp
Old Jun 3, 2014 | 09:27 PM
tibbytib's Avatar
Why stop at 4 when you can go 6? I've always had 6 channel pre outs. They work great if you want to really control the sound coming from all your front and rear speakers and subs.
4 is definitely sufficient for most folks. I'd steer clear of 2. Just no where to expand if you ever feel the need.
Old Jun 4, 2014 | 05:59 AM
If theres only 2, and you want to add multiple amps, you'll need a 3 way crossover, like these
http://www.sonicelectronix.com/cat_i60_crossovers.html
