2 Probs after Gauge install
Old Jul 4, 2001 | 04:03 PM
silv3rstone's Avatar
Vehicle: 2011 Genesis 2.0
Default 2 Probs after Gauge install
After installing APC indiglo gauges in my 99 tiburon i have one big problem and one minor one.
- My clock is not working anymore. I followed the directions on the website that Random posted up but didn't diconnect the wires behind the top part of the dash except for the fog light plug. So, air con, fan, blahblah were kept plugged in(except for disconnected heater cable) While leaving the top part of the dash left apart i went for a ride to make sure the gauges work and that the needles were adjusted right. and now nothing....they are completely out. the plug is still connected, i reconnected it just in case. Also, for a little while the rear defrost button was out for a little bit but i just kept pushing the button and then it started working! anyone know what's going on? everything else is working fine? does it have anything to do with me not disconnecting the battery? HELP PLZ!!!
- On the ash tray reconnection i believe i took apart the thermal fuse box, i can't seem to put it back together, whatever the white plastic box thing was i undid it, so, now im kinda lost on putting it back together....i looked at the picture on the gauge install and can't seem to see anything that looks like a thermal fuse box...was the white thing it? if so...does anyone know how to put it back together?
THANKS FOR THE HELP EVERYONE.
DeK3
Old Jul 4, 2001 | 06:04 PM
If the clock is out, it is because it is disconnected. It is a bitch, but you have to rip your dash apart and reconnect it. It is a simple connection, and a simple device...it could be broken/burned out, but I doubt it.
On the ash tray thing...does the ash tray light come on but the lighter doesn't work, or are they both out?
Old Jul 5, 2001 | 04:47 AM
-The clock is perfectly connected i reconnected it about five times and turned on the car and nothing happened.
-The ash tray light does come on but the ciggarette ligter does not work.
Thanks random
Old Jul 5, 2001 | 06:52 AM
Viper966's Avatar
check ur fuse the ashtray and the clock are on teh same fuse i know cuz ive blown it 2x
Old Jul 5, 2001 | 08:16 AM
Ash try light runs off a different circut that the lighter itself, so the fuze could be the cause. Check that.
Good Call Viper!
Old Jul 5, 2001 | 01:36 PM
Jaws99's Avatar
I have the same problem with the rear defrost it still doesn't work and all the fuses are ok and the dealership even replaced the switch and still nothing. What's up with that. Oh and as far as your clock goes it is connected to the same fuse your power mirrors are on if your mirrors work than it's not that.
Old Jul 5, 2001 | 01:59 PM
Tiburon_69er's Avatar
yep I have the same prob with my defroster too! The button works but the damn thing wont stay on!!!
Old Jul 5, 2001 | 02:04 PM
Thanks for letting me know that the fuse is the same for the clock and the lighter, but the problem is, is that i took apart the thermal fuse box thing on the lighter (the small plastic casing) does anyone know how to put it back together??? Please...?
Old Jul 5, 2001 | 03:38 PM
Viper966's Avatar
hey dek apc doesnt maek guages for the 99 tib....
Old Jul 5, 2001 | 05:50 PM
If the defroster does not stay on, you have the cruise cable plugged into the defroster switch. Look at my Gauge Install FAQ.
You need to color code the wires and dots.
If that is not done...if they do not match, the buttons will not work right.
