Velosters look so much better when lowered
Old May 21, 2012 | 12:39 PM
Old May 21, 2012 | 01:26 PM
turbosocks's Avatar
that is a very very nice lookin' Veloster!!! Absolutely love the wheels on that car..
I am at the point where as long as the color is not red or black, ill pretty much take any Veloster turbo on the lot, come august..
Old May 22, 2012 | 01:27 PM
briando's Avatar
Vehicle: 2009 Hyundai Sonata
i'm still on the fence with lowering my Veloster. but how low can i really go without messing with handling around corners. let me know folks. thanks
Old May 22, 2012 | 01:34 PM
My Genesis handles so much better with coilovers on.
Old May 22, 2012 | 04:28 PM
Lowering a car wont hurt handling unless you do it in a ghetto way (i.e. cutting or heating springs). By going with an aftermarket spring or coilover set up, the car will handle waaaayyy better than stock!
Old May 22, 2012 | 08:20 PM
wheel_of_steel's Avatar
Depends on how low you go, and the geometry of the veloster. Usually lowering a mcpherson strut car will also lower the roll center more than the center of gravity, increasing the roll couple and increasing body roll. However, this is traditionally offset with a higher spring rate so nobody notices.
Old May 23, 2012 | 06:22 PM
Neziah's Avatar
Vehicle: 2012 / Veloster
I've been sitting on a set of springs for a month or so now after I realized there are no after market shock replacements out yet. Trying to decide on just putting in the springs and living with the crappy shocks for a while or if I should just pony up for a set of coil overs... ><
Old May 23, 2012 | 07:32 PM
As long as you dont go low enough on a MacPherson strut system that fully compressed the lower A arms are below horizontal you're ok. Below that you start decreasing outside tire negative camber when cornering forces are applied, which is bad for handling (and safety).
