Wont start... *sigh*
Old Aug 25, 2004 | 11:28 AM
Hobgoblin's Avatar
Vehicle: 2015 Subaru WRX
Default Re: Show us what you got
For some reason my car jsut decides to up and die this morning... I dont know. Is there something behind the dash that would make it not start if it werent connected, besides the hazards? I took my dash off for painting, I drove around fine, with no problems while the dash was off for two days. I put it back on yesterday morning when I got off work and now I cant get it to start for anything! :roll: I made absolutely sure that I connected everything back in the right places (I labeled everything as to where it went as I took it off). Would something drain the battery while its disconnected? Im at a loss.... 02.gif
HELP PLEASE!!!
Old Aug 25, 2004 | 11:37 AM
Default Re: GB: Speed-Factor Basic Turbo Kit
are you getting any power at all? (dome lights, door lights, door ajar light)
Is it at least trying to turn over? Have you tried to jump start it? Check your battery terminals, is there a loose connection? is there a lot of corrosion?
Old Aug 25, 2004 | 11:39 AM
Hobgoblin's Avatar
Default Re: Wont start... *sigh*
Im getting everything as far as lights and sounds go.
Its trying to turn over, it just wont "catch".
I looked at and cleaned my terminals, there wanst really anything on there to begin with...
As far as a jump... everyone is at work.
**Does anyone think that a loose or grounded wire could be the problem? I dont know how it could have gotten worse overnight... but... may this have something to to with it?
Old Aug 25, 2004 | 12:05 PM
the alternator?
spark plugs?
:x
Old Aug 25, 2004 | 01:01 PM
Default super 60 turbo questions
do you have any mods? how many miles on the car? is it acting like it's about to start but just won't finish turning over?
Old Aug 25, 2004 | 01:10 PM
Hobgoblin's Avatar
Default size for the lines?!
Ive got a CAI as far as under the hood...
the motor has 23000 and the car itself has 67000
I cant get it to fully turnover... and while its turning, the whole car shakes... more than usual
Old Aug 25, 2004 | 04:16 PM
Dweet's Avatar
Default Re: Calipers
sounds like a timing problem. but taking out your dash wouldnt cause that. Thats very odd. Well what I would do is make sure everything is grounded properly. If that fails, get the ECU pinout and a voltmeter and start prrobing to make sure everything is peachy.. im having the same issue in my elantra right now. But it could be a number of things at this point because I am hybrid'ing two cars together.
<span style="font-size:36pt;line-height:100%"><span style="color:red">*DOUBLE POST ALERT!*</span></span>
make sure you plugged EVERYTHING back in. I just figured out my problem is the MPI relay. Make sure you plugged it back in bro or you'll never get it started!
Old Aug 25, 2004 | 05:26 PM
Default Re: My experiences with PowerChip
Dweet, cut out the double posting man. Use the edit button high speed.
Jared, I know this is stupid, but it's in neutral right? You didn't mess up anything on the clutch did you?
Does your stereo come on? Lights?
Old Aug 25, 2004 | 05:44 PM
iamcyclopseatme's Avatar
Default Re: kspec manifolds
Hrm.. Id say ignition if its really shaky when trying to start.. Timing got screwed, but thats just off the wall.. Id check plugs/wires/coilpack..
Old Aug 25, 2004 | 06:34 PM
cdogtibby1's Avatar
Default Re: Custom Short Shifter.
haha... i know what it is dood. same thing happened to me.. i was wiring up my neons though. you threw the ECU fuse.... look under the hood at the fuse block at the ECU fuse... i will GUARANTEE it is out. tell us what ya find
