Water Leaking Into Triple Pod.
The tibs actually have four drain tubes from the sun roof, one from each corner. With that in mind I would be more pron to think you either ran a screw through one or it came off the sunroof frame.
<div class='quotetop'>QUOTE (Mad-Machine @ May 5 2006, 11:09 PM) <{POST_SNAPBACK}></div><div class='quotemain'>how badly damaged did it get?</div>
Not really sure.....If you look at the drivers window and the passenger window, you can see there is a slight differece in the way they line up. But it's not that noticable. I don't think it was that badly damaged.
