Urgent: Help Needed. Incredibly Violent Idle W/ Flashing Cel
Old Oct 12, 2005 | 07:39 PM
Screwdriver's Avatar
My friend was driving my car with me next to him.
He isn't used to the Tib, so his shifting was off, but nothing too serious.
All of a sudden, the car starts vibrating VERY rough at idle. You can feel a pulse at idle. The check engine light began flashing as well (It was on prior to this due to a failed cat).
Throttle response was weak as well.
The car did NOT stall and got me home ok. It started back up as well. Temperature was normal. All the belts seemed there (couldn't see too well)
The only thing that felt different (could TOTALLY be psychological) was the clutch had more play than usual.
Other than that, I am clueless.
Please list any realistic possibilities and ask any questions. I will monitor this post late tonight.
Thanks in advance.
Old Oct 12, 2005 | 07:45 PM
Tibminn's Avatar
Id say check your plugs and wires. If its idling that rough it could be missing and thats a good place to start lookin
Old Oct 12, 2005 | 07:50 PM
hamhead's Avatar
^^ Agreed. Last time you did that stuff?
Old Oct 12, 2005 | 08:06 PM
Never did.
The previous owner said she had a tune up in Feb or approx. 10-12K miles ago.
She thinks the wires and plugs were changed.
Is misfire a sure enough guess? Would it be the only cause of a flashing cel?
I have the Seafoam fuel additive in the tank as well (just thought I'd' throw that in there)
Old Oct 12, 2005 | 08:09 PM
Raven997's Avatar
Vehicle: 99 Tibron
plug wires was my first cel in her and it felt just like that, try replcaing them
Old Oct 12, 2005 | 08:23 PM
Just ordered a set of PRDs. Hopefully, the problem is plug wire related. I can't help but doubt that. The idle was noticably rough.
Old Oct 12, 2005 | 08:47 PM
zoned019's Avatar
Vehicle: 97 Tib
..not just plug wires.
get plugs too mang smile.gif the plugs themselves go more often than the wires do.
Old Oct 12, 2005 | 09:42 PM
Yup.
Check the engine bay yet?
Maybe something came off?
Tis possible my mang.
Check your Idle Bypass setup.
Old Oct 12, 2005 | 09:46 PM
tanc's Avatar
Vehicle: 1997 Tiburon
I'm curious because I'm not sure if this is true or false. By adding seafoam to clean your engine etc, which would cause the carbon to break apart and burn. Could of there been a crack or leak in your gasget or piston rings that the carbon acted as an isulator? Now that the carbon has been cleared you might be running into problems depending on what the carbon actually glogged. How many miles on your engine? I think I heard MadMachine talk about this a while back.
Old Oct 12, 2005 | 09:49 PM
Did you get the CEL scanned?
