Tiburon 2003 (problems With Rail's Inyectors), Problems with rail's inyectors
Old Jul 11, 2011 | 04:25 PM
Blacktor's Avatar
Vehicle: Tuscani 2003
Default Tiburon 2003 (problems With Rail's Inyectors), Problems with rail's inyectors
Hello, i am from Chile, and i have a 2003 Tuscani (Tiburon, Coupe) 2.0 VVT, and i have problem with the rail's inyectors, because I've noticed that some gas comes out from the pressure regulator, and i dont really know if it is possible to change only the part that is marked in blue??? or what precautions I have to have to change that part..???? in which direction the nut is loosened???
here i have a video to show you what is the problem.. and when the vehicle is on, leaves a lot more gasoline.. >.<
http://www.youtube.com/watch?v=eWlW0...layer_embedded
can you help me pleasee!!
Old Jul 11, 2011 | 04:34 PM
that part can be replaced its the fuel pressure regulator, should just unbolt
precautions? disconnect the battery(let it sit for a second to be on the safe side) and have a rag around to pick up the extra gas
Old Jul 11, 2011 | 11:47 PM
Blacktor's Avatar
in which direction the nut is loosened???, because i cant reales it.. >.<
