starting problems
Old May 3, 2011 | 06:05 PM
my98tiburon's Avatar
Vehicle: 98 hyundai tiburon
Default starting problems
ok so i replaced my camshafts yestrday, i got ahold of a 1.8 head from a junkyard so i put both 1.8 cams in my 2.0 head ( i dnt knw if it makes a difference) but after having compression the prior day it seems i lost compression in all cylinders
now my question is that i reused my stock headbolts could they have stretched and air is leaking through the head gasket?
im buying new headbolts anyway because i shouldnt have tried to cut corners but im just curious on your guys opinions
Old May 3, 2011 | 06:21 PM
ChattTownShark's Avatar
Vehicle: 2001 tibby
I re-used my head bolts when i did my cam swap I have no problems at all make sure its stamped with a j2 - and if it is your timing is prolly off a notch. check back
Old May 3, 2011 | 10:38 PM
Cylinder head bolts may be reused without limitation, per Hyundai. ^ what he said. I made a DIY for setting the timing, it's around here somewhere . . .
Old May 4, 2011 | 05:55 AM
Yea I used the DIY for timing got the 5 links between intake and exhaust cams, cam gear is lined up and crank is at top dead center.
I torqued the bolts to the right foot lbs then did the 60 degrees and after the leakdown test and compression test got nothing
Should I torque em more?
Old May 4, 2011 | 08:42 AM
Vehicle: 2001 tibby
give me a picture and i used only 10lbs of torque for mine.. either you have the wrong cam or its off timing.. its a easy mod so i would suggest taking it off and looking again.
