Speed/performance Sencer
Old Nov 9, 2006 | 06:37 PM
deadlybydesign's Avatar
So get this I went out this morning, started my car, and went to drive off and i let off the clutch and it seems like it's sliping i look down and I'm still doing "0 mph" (at this time i'm doing atleast 15) lol so is it just the sencer or is my car f***ed? ANY help at all I'd owe you my soul.
Old Nov 9, 2006 | 07:16 PM
Caj Darkmoon's Avatar
Make sure you aren't having electrical problems. When I had my old Sentra and the battery would go sometimes the speedo would cut out once the level got low enough in the battery.
Old Nov 9, 2006 | 07:23 PM
landcruiser06's Avatar
Check your fuses
Old Nov 11, 2006 | 03:32 AM
but its not only the speedo my moter is draging ass HARD so is that fuses too?
Old Nov 11, 2006 | 05:37 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
First you need - to know what problem you are having.
moving to general performance.
PS. no need to quote post right abouv yours
Old Nov 11, 2006 | 07:35 AM
No fault, this is normal. 15 is a bit high, but it will not register speeds below 10. Reason being, if you're in a parking lot, you shouldn't be looking at your gauges, keep an eye out for kids.
Old Nov 11, 2006 | 07:48 AM
pile_of_rd1's Avatar
^ Once again... Seriously.. WTF
Anyways.... Go outside and take off your speed senson, its on the back of the trans.. its blue, cant miss it. See if it has a shaft and a plastic gear on it, if it comes out in pieces, then you got some problems, thats what commonly happens. And your clutch feels like its slipping? its either going to grab, or slip. When my trans started going my speedo did that, I lost second gear, then a day later speedo, then a week later the trans was cracked and Scotts not going anywhere. owned.gif
Old Nov 11, 2006 | 11:17 PM
^^ dude, they do that new from the lot man. They don't start reading until 10 MPH. Your speedo will start at 0 and then all the sudden jump to 10mph.
It's a gear driven system that converts mechanical motion to a pulse and sends that to the ECU. If he were having problems with that, the needle would be bouncing, it would register normally, just bounce all over the place, or sometimes just plain not register at any speed. I think the problem he's having is how the car was designed.
Old Nov 12, 2006 | 10:38 PM
no mines not reading at all like high way nothing still going 0
Old Nov 12, 2006 | 11:43 PM
i had that same problem when i fist got my car. like the speedo was superglued to the bottom no matter how you drove. it did that on and off. i took it to my mechanic and he had to open up the gauge and repair it somehow. i need to ask him how he did that. it has something to do with the gauges i think. once he fixed it, it never happened again.
