Rough Idle
Old Sep 17, 2005 | 12:12 PM
I tried to search and came up with nothing. Anyway my car has had a really rough idle lately and I was wondering what I could do to help this. My mods are: MBRP exhaust, headers, aem cai, bbtb. I have the voltage stabalizer from the BG and i thought that would help but it didnt. Hopefully you guys can help me out
Old Sep 17, 2005 | 12:30 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
how long do you have rough idle?
if you press accelerator slightly (let's say so that engine run on 800-900 rpm) does it run ok?
Old Sep 17, 2005 | 12:33 PM
Role Reversal's Avatar
Vehicle: 05 Subaru WRX
which bbtb do you have? cause recently i have discoverd that the shark racing one causes a vacum leak.
Old Sep 17, 2005 | 05:39 PM
Zman's Avatar
I had the same problem last week and I thought about cleaning the TPS connector (plug) with some electrical connector cleaning spray, and with the advise and help of a friend I did it and not only cleaned that, but also the plug of the idle motor (behind the IM, where the big hose is connected). I also took out the idle motor (or bypass valve I think it's called) and cleaned the holes with carb cleaner.
You wouldn't beleive how good it idles now, it idles like a champ, steady at 800 rpm.
Also, a lot of black dirt came out of that little valve, I think it's exhaust gases deposits. My friend is a mechanic at the Hyundai dealer locally, so he new where to start...
Old Sep 17, 2005 | 06:30 PM
That sounds like it would help. Ill try tomorrow. And yes it does run fine when i push the gas a little
Old Sep 19, 2005 | 07:36 PM
well i tried it and it didnt help. Any other suggestions?
Old Sep 19, 2005 | 08:18 PM
As soon as I come to a stop, the wheel shakes and the idle goes back and forth about 100 rpm. if i turn the wheel and activate power steering, it gets rougher. same with windows. when i give it a little gas its all better. could it maybe be i need a bigger alternator? i am running 2 batteries
Old Sep 20, 2005 | 01:04 AM
Dmitry's Avatar
<div class='quotetop'>QUOTE (Ericy321 @ Sep 20 2005, 05:18 AM)</div><div class='quotemain'>could it maybe be i need a bigger alternator? i am running 2 batteries
Why do you have 2 batteries?
stock alternator can be too small to charge 2 batteries simultoniuos.
And it's ok when you open/close windows, turn steering wheel at idle - rpm can go up and down. It's ok.
