Reusing headbolts??
Vehicle: 98 hyundai tiburon
I've heard its not good to reuse them because they stretch when you torque them, i will be selling the car so wud it be really important to get new ones????
Hyundai says Beta head bolts may be re-used without limitation. If I recall correctly, they also say to torque them, then rotate them a specified number of degrees, then rotate again. There is a special tool to monitor the angle.
Never reused head bolts in my life.
I don't care what Hyundai says, not worth it to save less than $10
And the "specific number of degrees" is called a yield, just so you know
Do you change your shoelaces when you put your shoes on every time also? Unless you are running big boost, re-using stock head bolts is a perfectly sensible way to save a few dollars.
edit: maybe once or twice. It would give even me the heebie-jeebies to re-use stock head bolts like 5-10x but then I also can't think why I would have the head off that much.
I dug it out of Webtech back when I started the head work on my spare cylinder head many, many moons ago.
Installation instructions:
http://www.newtonnet.co.uk/coupe/ser...d=12097#_12097
still looking for reuse specification . . . webtech not letting me in lately
This is in a table on there somewhere, but here are two sites that copy/pasted it from the Hyundai TSB
http://www.rebuiltautoengines.com/hyundai-articles.html
http://www.automotix.net/autorepair/...uide-2373.html
Google did find MadJohn saying they use stock head bolts on high power builds in Korea
https://www.hyundaiaftermarket.org/f...p?/topic/29577
This is in a table on there somewhere, but here are two sites that copy/pasted it from the Hyundai TSBhttp://www.rebuiltautoengines.com/hyundai-articles.html
