Relay?
Vehicle: 2011 Kawasaki ZX6R
I know I need a power distribution block for 2 amps; What I need to know is if its safe to connect the remote turn on wire from my head-unit to 2 amps without a relay.
The amps are both 360W max, but will be running at 170W each(small I know). Should i just pick up a relay when i grab the power block or should the H.U. have enough current for these 2 small amps?
The Head unit is a Dual something or other, I'm unable to check the exact stats on it right now.
it should be fine, you can run like 2-3 things off of it without voltage issues, you dont want to put many more cause theres almost no power running through it, just enough to send a 'turn on' signal
Cool thank you. Now Just one more question about this.
How should I go about connecting it to the second amp. Do i just run a wire from the remote turn-on from the first amp to the new amp? I'm not sure if this would cause any problems or not.
If this is the way its suposed to go, then i have the wire from the H.U run to the plug on the first amp; Stick another wire in that same plug and run it to the 2nd amp. right?
It really does not matter, all the remote wire is 12v and tells w/e to TURN ON. you can go Deck -> Amp -> Amp. Or you could T them off mid line and split. Just make it easy on yourself and go into one AMP and then into the other one!
<div class='quotetop'>QUOTE (dddude55 @ Feb 19 2007, 04:37 PM) <{POST_SNAPBACK}></div><div class='quotemain'>If this is the way its suposed to go, then i have the wire from the H.U run to the plug on the first amp; Stick another wire in that same plug and run it to the 2nd amp. right?</div>
thats correct
and like trancematic said, it really doesnt matter, its all choice, like i got mine split a foot before the amps just so i dont see any wires going amp to amp,
thats correct
