refreshing my 2000 Tiburon
Old Jun 5, 2011 | 05:59 PM
Loneshark's Avatar
Vehicle: 2000 Tiburon
Default refreshing my 2000 Tiburon
Hello once again. I have been seriously contemplating selling the Tib for a few months now as I am finally making decent money. I was thinking long and hard about selling or rebuilding, and its come down to rebuilding. There is simply no car out there that has the curb appeal of my cobalt blue Tib, and to sell it would be just dumb…. i think. perhaps the future holds an entire beta2 swap with supercharger.
Im looking at replacing all 4 calipers, Brake master cylinder, all 4 hubs, inner tie rods, outer ball joints. new eibach springs, and new KYB struts.
Im also considering replacing the entire control arm with bushings as a set if the price is right after i conduct an inspection of the rubbers.
If you had to choose new calipers, what brand would you go with ?
RockAuto has the following manufacturers for sale:
Calipers
Centric
Raybestos
A-1 Cardone
Nastra
Beck Arnley
Auto 7
Wagner
Master Cylinder
Dorman
AUTOSPECIALTY / KELSEY-HAYE
Centric
Raybestos
A-1 Cardone
Beck Arnley
Auto 7
Wagner
Hubs
Front
Timken
National
SKF
Beck Arnley
Auto 7
Rear
GMB
Value Pro
Raybestos
Timken
National
SKF
Beck Arnley
Tie Rods and Ball Joints
Auto Extra
Reybestos
Mevotech
Deeza
AC Delco
Beck Arnley
Auto 7
Moog
Old Jun 5, 2011 | 09:00 PM
All I can say is: if it is made in China you don't want it. As for brands, it can be a crap shoot. I bought a part from a national rebuilder that turned out to be a reman'd Hyundai casting.
Old Jun 5, 2011 | 11:32 PM
Loneshark's Avatar
yea, thats what im afraid of, ive seen some pretty crappy reman jobs, i suppose this topic would take some time to develop as people chime in with their thoughts on what they bought. thanks stocker
Old Jun 6, 2011 | 07:26 AM
SR Tech's Avatar
Vehicle: 2011 Tuscon
I'm all about timken when it comes to bearings and also a big moog fan.
Brakes parts id just go with whatever your local auto parts store backs with a warranty.
I can't remember if your from out west or not, but give the brakes lines a check too.
I had a line blow on the tib last year, rusted right through. threw a set of vicegrips on the end to cap it off so i at least and 3 brakes until i could fix it B)
I personally wouldn't replace the front hubs unless the spline was bad or the hub cracked. Popping a new bearing in is essentially starting fresh.
STILL... i don't recommend replacing something if its not worn/broken. You go to do inner/outer tie rods and don't take your time and measurements and throw the toe off to all hell you'll be trying to get it back to spec without an alignment machine lol
Old Jun 6, 2011 | 11:25 AM
Loneshark's Avatar
thanks, when i changed the pads and rotors last year, the front pistons in the calipers had rusted and seized, so i pulled them apart and rebuilt them. Also i flushed the front brake lines to get the condensation build up out. the rear pistons werent too bad but were showing some signs of rust due to water in the lines.
i understand the "if its not broke, dont fix it" mentality, but tie rods, ball joints, bushings, and bearings wear out unexpectedly, so better to replace them now while i have the front end apart. thanks for your input on Timken and Moog too !
Old Jun 6, 2011 | 01:15 PM
IMO: Replace stuff only as it fails, unless you just have money falling out your pockets.
Old Jun 6, 2011 | 06:33 PM
Loneshark's Avatar
all those parts have 126k miles on them, except for the springs and struts. they are being replaced no matter what. does kspec still have the complete bushing sets ?
Old Jun 12, 2011 | 01:44 PM
Loneshark's Avatar
this is my current expenditure sheet on the refresh.
all prices are estimates based on RockAuto pricing except for sway bars and rotors
PURCHASED
381.55 KYB struts and mounts
206.00 eibach springs
279.00 kspec bushings
TOTAL 866
NEEDED
inner tie rods 8 each = 16
outer tie rods 10 each = 20
ball joints
sway bars
400
axles 46 each
hubs
front 30 each = 60
rear 45 each = 90
calipers
front 206 pair
rear 206 pair
rotors and pads
130
gaskets
intake manifold 4 each = 8
TOTAL 1228
EXTRAS:
LITHIUM GREASE
BRAKE FLUID
AXLE GREASE
BEARING GREASE
Red Spray Paint
Clear Spray Paint
Hyundai decals
funds needed
(axles)92 + (bearings)150 + (calipers)412 + (rotors)130 + (IM gaskets)8 + (sway bars)400 + (inner/outer tie rods)36 = 1228
ESTIMATED TOTAL 2,158
