QUICK QUESTION-Please answer fast
Old Nov 11, 2004 | 12:34 PM
'treezy's Avatar
Default Re: Twin Engine Tib
OK...
I'm thinkin of gettin a rside bbtb but it has no coolant hose nipples.
I can route the hose in a 'U' back into the block (the bypass DIY), but
Here's the thing...I live in Seattle and it gets pretty cold in the winter.
Is there a chance that the butterfly valve will freeze shut if no antifreeze
is connect to the bbtb? If so does any1 know where I can find a bbtb
WITH the coolant hose nipple?
Old Nov 11, 2004 | 12:37 PM
wattsup4800's Avatar
Default QUICK QUESTION-Please answer fast
Just make it into the U shape you will be fine
Old Nov 11, 2004 | 02:00 PM
javageek's Avatar
Default Re: Help with HPF & LPF
I think the Tigerlilly BBTB has the coolant setup on it. I removed mine, but then again I am down here in Florida. laugh.gif
Old Nov 11, 2004 | 02:33 PM
Agarwal's Avatar
There won't be any problem. The guys here (including me) are running the BBTB without the coolant line, and it gets down to -40c in the winter (try to get that in Seattle wink1.gif); never had a problem.
Old Nov 11, 2004 | 02:43 PM
supercow's Avatar
Default Re: FS : eibach lowering springs and other stuff
has anyone run into problems with that mod on the stock tb?? I was holding off on doing it on my car till the spring but if it's not going to be a prob. then I might just do it now. laugh.gif
Old Nov 11, 2004 | 03:03 PM
Agarwal's Avatar
Default Re: QUICK QUESTION-Please answer fast
My BBTB is a stock bored one; so no, you won't have any problem neither wink1.gif
