Power Window Problems
Old Nov 2, 2006 | 02:18 PM
all of a sudden today as i was driving the powerwindow part of my door fell loose and i had take the door off and fix it. but when i put it back together the pass side window wouldnt work.
now first thing i though was that the connecter maybe had fallen loose for some reason so i took the door back off and tried to snugg it back into place. well it was allready in pleanty tight.
so secondly i checked the fuse but that wasnt it obviously because the driver side is still working. so now i'm back home and im in the process of taking off the pass side door now to see if maybe somehow someway that connecter has gotten loose and the circuit isnt working because of that.
it probably wont be that but does anyone else have a clue on what i'm dealin with??
Old Nov 2, 2006 | 07:39 PM
NY Turbulance's Avatar
had the same problem, except the passenger side went down on the 4th click, theres nothing you can really do but replace the master switch, thats what i ended up doing. You may have just damaged the connector when it popped out or in the process of taking the door off
Old Nov 2, 2006 | 08:27 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
kinda a far shot but possibly a relay? i know there's a power window relay above the clutch pedal and dead pedal, against the fire wall-... it's a pain in the @$$ to get to and further more they're not labeled (it's a tiny black one similar to the ones in the fuse/realy box under the hood)-... hold on it gets worse-... and if you plug them in improperly you'll have to buy another relay (how do you think i know this?), or find another relay same specs of something you don't use or is broken and use that one in the power window spot (i switched the fog light relay for the power window relay). like i said it's a long shot but good luck!
Old Nov 2, 2006 | 11:11 PM
StrikeEagle's Avatar
I had a problem similar to this. I felt ever so stupid when I realized I had the window lock on...
Old Nov 3, 2006 | 03:15 AM
Old Nov 3, 2006 | 04:19 AM
Mad_john's Avatar
check your switch and the main switch as well its not the window motor
Old Nov 3, 2006 | 05:58 AM
hamhead's Avatar
I'll be honest.
I spent a day tearing the door panels apart and looking for a problem on why passenger side didn't work.
Had the window lock on.
Old Feb 8, 2007 | 09:01 PM
jgrove111's Avatar
Good info for stupid ppl. Thought the cold jammed up the passenger power window.....it just froze my brain...turned off the lock lmao.gif
Old Feb 8, 2007 | 09:05 PM
you get my "good job searching" award of the year.
glad you figured it out.
