Orifice tube in AC
Old Oct 1, 2004 | 09:05 PM
gotspeed13's Avatar
Vehicle: 1998 Hyundai Tiburon
Default Re: Which Generation your favorite?
<span style="color:cyan">Where is the orifice tube in the ac system? I know it's in the low side tube but where?</span>
Old Oct 3, 2004 | 07:56 PM
gotspeed13's Avatar
Default Re: New GB for RotorPros! Pads, Brake Lines, Rotors!
<span style="color:cyan">Anyone?</span>
Old Oct 3, 2004 | 09:48 PM
Default Re: Need Ideas
Sorry man, your question doesn't compute.
Old Oct 3, 2004 | 10:02 PM
gotspeed13's Avatar
Default Re: FS - Rockford Fosgate speakers
<span style="color:cyan">The orifice tube is a filter that also kinda controls how much coolant flows through the system. It is in the liquid/low pressure tube but I don't know where exactly and I can't find it on webtech.</span>
Old Oct 3, 2004 | 10:14 PM
iamcyclopseatme's Avatar
Default Re: FS: 2004 Trek 7200 bicycle
Alls I found that KINDA match what you are talkin about (which I still dont understand) is this http://www.hmaservice.com/webtech/iindex.a...id=12339#_12339 Scroll down, theres a Thermostatic switch and an A/C pressure switch..
The only other thing is the Pressure Side Service Port maybe? http://www.hmaservice.com/webtech/iindex.a...id=12368#_12368
What are you trying to do?
Old Oct 4, 2004 | 08:47 AM
gotspeed13's Avatar
Default Re: Installing an Autometer Tachometer with Shift Light
<span style="color:cyan">I'm trying to get my ac working again. Every time you take the compressor off for a significant amount of time, you are supposed to evacuate the system and replace the drier because moisture gets in there. It is also recommended to change the orifice tube. But that I cannot find. Thank you for your help but I had already looked over that.</span>
<span style="font-size:36pt;line-height:100%"><span style="color:red">DON"T DOUBLE POST!!!</span></span>
<span style="color:cyan">Well, after having the same wrong part sent to me three times, I have found that there is no orifice tube. I searched google for it and I found that hyundai's use the orange color coded orifice tube, so I thought that's what I needed but apparently there is not one. Anyway, there you go.</span>
Old Oct 4, 2004 | 04:08 PM
Dweet's Avatar
Default Re: wuts goin on with my tib..
who needs AC? its just a power drainer
Old Oct 4, 2004 | 04:29 PM
JalemX's Avatar
Default Re: A/C BS?
yah well if you live somewhere it's warm all the time, in the winter u need defrost.
Old Oct 4, 2004 | 04:30 PM
gotspeed13's Avatar
Default Re: Orifice tube in AC
<span style="color:cyan">Exactly. That is why I am trying to get it together before it gets too cold.</span>
Old Oct 4, 2004 | 05:16 PM
Dweet's Avatar
Default Re: FS: Brand new 340cc BETA I injectors
blah, everyone around here takes their AC out of their DSM's. Defrost will still work smile.gif just not as well
