Odyssey Batteries Pc545? Canking Amps?
I have the pc 680 its pretty light I dont no if id go lower to the 545 unless the car is going to be for racing purposes, I wouldnt want to be stuck soewhere cause my batt was borderline wether it would start the car, I dont think neone else has had the pc 680 so I was kinda just going by what others said about it being enough to start small engines u can push it down some more if u want but i dont think i would unless u have jumpper cabels and r always around someone who would help
Vehicle: 2000 carbon tiburon
A deep cycle battery needs a slow charging system to charge it correctly, Are cars have a fast charge and over time will kill a deep cycle battery over a regular battery any day. I have 2 deep cycles mounted in my truck for the sterios sytem but have them split for a voltage regulater to cut the charge down.... i would not recomend a deep cycle for every day use. But they do work great for sterio systems. fing02.gif
my bad maybe i should read the whole thing the soju it talking to me
i look at them they sould like they are good i might also look at getting one
thanks faith
you would make a good pimp you sure keep them hoe's in check
thanks faith
<div class='quotetop'>QUOTE (Mad_john @ Sep 23 2005, 07:00 PM)</div><div class='quotemain'>offtopic.gif
i do make a good pimp just ask abq and redzman they respect there pimp or ill have to choke a b!tch
