Obd2 - Pc
Old Feb 1, 2006 | 06:22 AM
Nice, but Ihave no laptop.
Old Feb 1, 2006 | 06:27 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
you can hook it to your PC, cable may be long enough!
and it's a good reason to buy cheap 486 or Pentium based laptop
Dmitry's Avatar
Old Feb 1, 2006 | 06:49 AM
mr_jeckel's Avatar
The description of the item says that it only works for Audi/VW vehicles. There are different OBD-II protocols. Usually a type of converter is needed change the protocol to serial data compatible with a laptop. Also, once connected to the PC, you need software to read and interpret the data. You can download free software from a couple of sites, but the software is usually very buggy and can be very troublesome to use. I think your best bet is to do some research and pay the money for a decent scanning tool. BTW, all cars after 1996 (I think) use the same OBD-II port. It is only the protocol that is different. Each protocol uses different pins on the connector and a different data format to relay information.
mr_jeckel's Avatar
Old Feb 1, 2006 | 07:09 AM
TiburonWao's Avatar
On the www.digimoto.com they show the deffenent OBD type used on the cars......
TiburonWao's Avatar
Old Feb 1, 2006 | 09:49 AM
that will work for VW / Audi cars... ours are not included. There are 3 types I believe... Ford/GM use one type, imports use another, and Chrysler uses another I believe. It doesn't look like Audi/VW use a universal one.
Our cars use an "ISO"
