the legality of HID kits
Old Jul 8, 2011 | 04:59 PM
Loneshark's Avatar
Vehicle: 2000 Tiburon
Default the legality of HID kits
today i finally got the tib inspected here in the "little confederate town" Norfolk, virginia. got to talking with the inspector about mods that fail inspections. he tells me things like LED bulbs, modified headlights, not having a catalytic converter, and the normal safety items like tires and brakes.
little does he know that i failed the inspection a few months ago due to my modified headlights having angel eyes in them... he didnt notice them... thank God.... also a fail was my LED red blinkers in the tail lights. and LED bulbs in the front corner markers.
so how have you gotten away with the visual inspection in your state if you have an HID kit installed?
i read this and this and found that HID kits are completely illegal, no matter if they are DOT approved, one thing has nothing to do with the other.
is that info accurate ?
edit, just wanted to clarify, that i know our lo beams are projector lights and are ready for HID bulbs.
Old Jul 8, 2011 | 05:12 PM
The Tiburon is fine. We have projector headlights. Reflector headlights with HIDs are a hazard to others on the road.
Old Jul 8, 2011 | 05:43 PM
Zekkal's Avatar
well lows are fine then... but what about highs? highs are just reflective, i havent ordered my highs yet just ordered 10,000k 35w for my lows, i was planning on the 10,000k lows and like a white 8,000k highs... but i dont know now
Old Jul 8, 2011 | 05:53 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
Highs are not worth it unless you live out in BFE IMO.. I have to flip mine on and off a lot on the highways I run. The warm up sort of kills it.
I have HIDs, no issue with inspection in TX.
Old Jul 8, 2011 | 05:55 PM
Loneshark's Avatar
Zekkal, just make sure not to use your HID high beams in oncoming traffic or while following someone else. and honestly you dont need HID for the highs.
DTN, i know our lo beams are ok for HID use... but what about passing inspections, how can i get around it ? do they make inspection ready HID kits, or just DOT approved kits.
Old Jul 8, 2011 | 06:21 PM
Loneshark's Avatar
Zekkal, as per your PM about people flashing you, adjust your headlights using this pic and numbers. perhaps since you just got your tib, the previous owner had them maladjusted.
Dotted lines in the illustration show center of headlights.
"H" : Horizontal center line of headlights from ground. 23.3 in (593 mm : With driver)
"W" : Distance between each headlight center. 42.1 in (1070 mm)
"L" : Distance between the headlights and the wall that the lights are tested against. 118.11 in (3,000 mm)
File Type: gif
Old Jul 8, 2011 | 06:32 PM
Zekkal's Avatar
@ Loneshark
thanks man, imma have to do that when i get the HID's in... i got flashed the first day i had my Silverstar Ultra's in.
@ Wytchdctr i do live in BFE, the closest town (churubusco) is 10 miles away and i get no cell reception in that town, im still runnin Dial Up internet, cuz 3G dosent have good enough signal
i only get cell reception in certain parts of my house, none in basement, 2nd floor is best 2-3 bars Max out of 7 bars
Old Jul 8, 2011 | 06:47 PM
Originally Posted by Zekkal
@ Loneshark
You don't want HIDs for high beams. They take too long to warm up and they don't have the same light pattern as standard bulbs. You will loose your ability to flash, and if you do flash, then you will burn out the HIDs much quicker. I would not use them for high beams.
Old Jul 8, 2011 | 06:51 PM
Loneshark's Avatar
good point there DTN and WytchDctr, i forgot about the warm up...
Old Jul 8, 2011 | 08:31 PM
accent03's Avatar
Vehicle: 2003/Hyundai/Accent
Im rocking switchback LED turn signals.
6k HID's
No catalytic converter
Illegal window tint
Not 6 inch frame clearance from the ground
And I passed PA inspection flawlessly
Just gotta know people
