Interesting problem with a 2001 tiburon
Old Oct 20, 2012 | 09:07 PM
  #21
bigfishmoney's Avatar
u starved the MFI too much. this happened to be just 2 months ago and i fixed it the next morning by paying extra attention
leave the car key turned over and let it crank for 15-20 second incriments, try many times-- resort to fuel additives as well to get combustion; use fuel system cleaner for example cause it has little forms of gas in it to help get it started
Old Oct 21, 2012 | 06:54 AM
  #22
i had a similar problem before and tried looking at that same relay, and i tried new ECU ( mine kept blowing main fuses) it ended up being some bad wiring at the alternator.
so i guess i'm just saying tripple check the harness. the section of wire that was bad i had looked at and touched twice before and didnt catch it was bad.
Old Oct 22, 2012 | 02:04 PM
  #23
psin2005's Avatar
Vehicle: 2001 Tiburon 2.0L
But no power to the fuel pump means that even if I got the engine started w/ additives it wouldnt run because its not getting any more fuel. (since the pump isnt getting any power)
Old Oct 22, 2012 | 02:05 PM
  #24
psin2005's Avatar
No fuses are being affected and everything else electrically is working fine. I'll try looking at the harness again.
