HOLD light?
Old Dec 2, 2004 | 09:11 AM
spiceflow's Avatar
Default Re: ARK SPEED RACING Discussion/Concerns
Today I noticed the warning light all the way on the bottom of the lights around the gas/temp gauge says "HOLD" in big letters. I've never seen this light come on, so I'm just wondering what it is for, and when it would ever come on.
Old Dec 2, 2004 | 09:19 AM
tibwrcsbj's Avatar
Default Re: I need some help on making a decision
I noticed it a while ago too. REDZ told me that it has something to do w/ the Deisel engines that some countries got. So don't worry about it.
Old Dec 2, 2004 | 09:40 AM
azwildfire's Avatar
i know that on my 04 elantra the HOLD light comes on if your SMARTA code does not match what the ECU expects *aka someone is trying to hot wire your car, or you got a new SMARTA unit and did not enter the code into the computer*
it illuminates and does not allow the car to start.
if it is flashing, it means it is in TEMP RUN mode, and allows you 50 miles before it shuts down the car
just fyi
Old Dec 2, 2004 | 11:18 AM
2bits's Avatar
Default Re: Ground effects problem
^^^^^^ now that is useful information
Old Dec 2, 2004 | 05:46 PM
Default Re: cat back exhaust and headers
Maybe for your 04, but not for the RD Tibs.
If you take your gauge cluster out, you'll notice that hole is taped off and has no bulbs.
it was there because Hyundai was thinking of doing a Desiel Engine for us.
Old Dec 2, 2004 | 05:56 PM
Tibbychick's Avatar
Default Re: corner lights for Gen 1
too bad shark racing didnt think to cover it up when they made their white faced gauges...its on all the time.
Old Dec 2, 2004 | 07:00 PM
Casper's Avatar
Default Re: Exhaust Question
Yea, the RD HOLD light was to be used for diesel engines (before you start Hold is lit until the glow plugs heat up). I did notice that it is taped off and I think it would make a good stock looking indicator light smile.gif.
Old Dec 2, 2004 | 08:18 PM
Default Re: Alternators
wonder if it would be a good place to stick an alarm LED?
Old Dec 3, 2004 | 07:24 AM
1997tibby's Avatar
Vehicle: 02 Accent
Default Re: 315cc injectors
or you could wire in your own little shift light!! nobody but you would know what it is!
Old Dec 3, 2004 | 09:15 AM
TibRacer01's Avatar
Default Re: FS:1st gen tib. OEM shark racing wing
<div class='quotetop'>QUOTE (Mad-Machine)</div><div class='quotemain'>wonder if it would be a good place to stick an alarm LED?</div>
That would be cool, but I think it would be a little too hard to see from the outside. You want the alarm LED to be in plain view from outside the car.
