High Light Reflector
Old Oct 31, 2005 | 03:42 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I noticed that highlight reflector in my right headlight has orange spots, lots of spots that looks like there is sand in headlight.
What to do? Can it be cleaned or I need to change the reflector?
Old Oct 31, 2005 | 06:34 AM
I would try cleaning first, D. Just be sure not to use anything too abrasive.
Which side is it? (Sounds like a personal question)
Old Oct 31, 2005 | 08:34 AM
Dmitry's Avatar
it's passanger side.
is reflector made from metal? or there is a crome film on it? if so crome could be gone away 02.gif
Old Oct 31, 2005 | 09:34 AM
funkypc's Avatar
ya, mine is the same... looks all yellow and crappy. is there any kind of reflective paint?
Old Oct 31, 2005 | 01:26 PM
duplicolor makes a high temp aluminum spray paint. can be found at auto parts stores.
sound like oxidation in the headlight, which is bad. spray is just a bandaid, and will probably hold in moisture causing it to spread quicker. sounds like its time to replace the headlight.
Old Oct 31, 2005 | 02:26 PM
the reflector is plastic with electroplated "Chrome" on it. A little more sturdy than the cheap chrome surrounds on the lights. You can probably pulls the lenses off and clean it with regular dish soap and water.
Old Oct 31, 2005 | 02:32 PM
hmm...now i cant remember if that peice in the rd2 was plastic or metal. im starting to lean towards plastic now.
Old Oct 31, 2005 | 02:33 PM
zoned019's Avatar
Vehicle: 97 Tib
I would bake the headlights, get them apart, then clean everything with soap and water as mentioned, make sure it's dry and then cook them again to seal them tight. But before you install them you might want to seal them with some clear silicone to make sure you don't get any moisture in.
tibby01, i'm pretty sure it's plastic for both gens.
Old Oct 31, 2005 | 02:39 PM
Dmitry's Avatar
I don't want to disassemble headlite twice, what if it wouldn't washed by soap?
Old Oct 31, 2005 | 02:53 PM
zoned019's Avatar
Vehicle: 97 Tib
Twice??
