Help Needed: Airbag Light On, Bright Fluctuating Instrument Lights
Old May 22, 2006 | 09:48 PM
Screwdriver's Avatar
I'm a MORON. I meant to say Air Bag, NOT ABS.
(Mods pls. fix if possible)
To reiterate, my Air Bag Light is on and today my check engine light came on. "Too much voltage being supplied"
I was at 17+ volts.
I bought a remanufactured Duralast Alternator. It is a 90 A capacity w lifetime warranty. Can anyone recommend any better?
Old May 23, 2006 | 01:19 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
17V is too much, check airbag fuse
PS I edited your first post
Old May 23, 2006 | 01:22 AM
zoned019's Avatar
Vehicle: 97 Tib
okay i saw this topic and like freaked out i was like I SWEAR TO GOD IT SAID ABS! LOL.
Old May 23, 2006 | 01:43 AM
definately your voltage regulator on the alternator. You need to swap alternators.
Old May 23, 2006 | 08:20 AM
New questions:
1) I just bought a Remanufactured Duralast Alternator. Lifetime warranty apparantly?!? . If I hadn't, could I have swapped JUST the Voltage Regulator? Or is it built into the alternator?
2) Could this cause the belts to squeak? They started squeeking at the same time this happened?
3) Can I wait till this weekend to fix or will this damage anything?
Thanks guys
Old May 23, 2006 | 08:27 AM
it can kill your battery, fry some fuses/relays
voltage regulator is in the alternator i think...better off replacing the entire thing you donno what kinda damage it could have done to the alternator
Old May 23, 2006 | 08:35 AM
Mad_john's Avatar
^^^^^^yo
Thank you for your interest in tuning your tiburon, simply type in the key words to your question into the search bar on RDTiburon.com, and you will most likely find your answer. If you do not find what you need, please feel free to register, post an introduction topic, then post your question in the appropriate sub-category. Your answer will be posted shortly! Tuners like you are who help to make up the growing hyundai community, and we're glad to have you aboard! Thanks for using RDTiburon.com!
Old May 23, 2006 | 07:58 PM
^^^ LOL. K-Rad.
Not only your fuses, but think about your ECU and all the little light bulbs in your dashboard.
Old May 23, 2006 | 09:08 PM
hprockets's Avatar
Vehicle: 2009 Hyundai Sonata
hmm. how hard is it to replace the alternator?
Old May 23, 2006 | 10:47 PM
a few bolts, a plug and a wire. when you put it back on, you have to tension the alternator... just get in there and look at it, it's pretty self explanitory.
It's not hard, takes maybe 45 minutes and someone to hold the alternator when you take it off and on.
