Head Removal
Old 12-19-2005, 12:54 PM
  #21
JonGTR's Avatar
They can be reused. Stockers stretch and shouldn't be reused too often, if at all.
Old 12-19-2005, 01:19 PM
  #22
wattsup4800's Avatar
gotcha, ok well i hope to take this off this week.
Old 12-21-2005, 07:57 AM
  #23
OK, i should have all the bolts off today. Once all the bolts are off will the head just come off? is there anything else i should know?
Old 12-21-2005, 08:51 AM
  #24
JonGTR's Avatar
The timing belt should be off and the cam sensor disconnected.
Old 12-21-2005, 12:17 PM
  #25
im pretty sure the belt is off, where is this cam sensor? Also, (might be a newbie question but i obviosly havent done this before) how much does the head approx weigh? I should be able to lift it out right?
Old 12-21-2005, 01:16 PM
  #26
JonGTR's Avatar
If it's just the head, then it's easy to pull off. If you still have the manifold/TB/Rail/etc. attached to it, then you might need some help. But it also depends on how strong you are.
Old 12-21-2005, 01:30 PM
  #27
i should have no problem then, the manifolds are off, and im not weak. But wheres the cam sensor
Old 12-24-2005, 12:09 PM
  #28
UPDATE, head is off. When is the group buy for port and polishing going on?
