Fuel Pump
I am going to get a new fuel pump because mine is shot. idk if ill do nitrious or antying like that but i was thinkin about the walbro 190...how much would one be? im lookin at ebay and i can find some for like 70-100. but what about just a NEW stock pump how much would that run me? and what about the 255. is going bigger bad? will it cause me to run richer or leaner? newb question i know lol. i know the 255 is probably over kill but if its the same price as the 190 i was just seein if its worth it
You'll need to replace the regulator with those. They flow too much. Just get an Eclipse GST pump for $25 off a DSM board.
you wont have to replace the regulator with that fuel pump
i have it in my car now
oh and as a pre warning
dont run with less than a 1/8 of a tank it will bog and shake if you give it to much throttle as its not designed to pick fuel up from the bottom of our tanks
and if your gonna run nitrous dont run with less than a 1/4 tank to be on the safe side
yes its kind of annoyin but if your to cheap to put 3 bux in gas you shouldnt be spraying lol
It depends on the filter that came with the pump and where it picks up the fuel. Some point straight down like the stock one, and some turn 90 degrees to actually face upwards and raises the pickup point about an inch.
