Fuel Injector Question
Old Nov 5, 2004 | 08:46 PM
Dweet's Avatar
Default Re: I can't access to this site from my home computer.
Injectors for Hyundais are too expensive. So I've been searching for a cheaper solution. I've found that mustangs have high impedance injectors. However they go to about 14.8 ohms. Webtech says that our car wants 15.9 +/- .35 ohms. Obviously 14.8 are out of tolerance. What would happen if I used these?
Old Nov 6, 2004 | 03:46 PM
TiburonWao's Avatar
Default Re: Defroster is Broken!
Ok... This is new for me.... I have in mind that High Impedance is everything over 13ohms.... And every car that is High Impedance will support anything between 13 and 16ohms.....
I'm wrong???? let me learn something new about this topic please....
By the way... If you want to find some cheap fuel injector, go here....
http://www.racetronix.com/
Maybe you know this webpage :roll: :roll:
Old Nov 7, 2004 | 01:46 AM
Cuda-Turbo's Avatar
Default Re: Stupid Question
I think that Gary is running mustang injectors with his speed factor kit, maybe hit em up.
Old Nov 9, 2004 | 10:06 AM
Dweet's Avatar
Default Re: dyno
Would these work?
http://www.racetronix.com/621020.html
Old Nov 9, 2004 | 10:18 AM
OdessitPashka's Avatar
Default Re: what gauges to get for boost??
Just to let you know, you gonna have to do some modifications to make them fit.
Old Nov 9, 2004 | 10:20 AM
Dweet's Avatar
Default Re: canadianshark's new ride
thats what i was curious on.. the resistance falls within the stock tolerance.. i'll have to rig it up i guess
Old Nov 9, 2004 | 10:22 AM
I think I remember someone trying to fit injectors on beta that were not meant for beta, and they had to extend something or w/e. It was a while ago.
Old Nov 9, 2004 | 10:23 AM
Dweet's Avatar
Default Re: Fuel Injector Question
well if i did the swap in the elantra i should be able to tackle this
Old Nov 9, 2004 | 10:37 AM
I think so too smile.gif I was just warning you smile.gif not saying that you cant do it, just wanted to let you know what you have ahead of you smile.gif
