Exhaust Help
You have several Options
1. Go get a new axleback exhaust from a dealer and pay way too much (dealer should have part numbers)
2. Buy an aftermarket catback system probably for the same prices as the axleback from the dealer and enhance your car's performance
3. Take it to a muffler shop and have them fix it
4. Go to a JY and get the axleback exhaust from them (cheapest route)
axle back exhaust? I only need one pipe thats about 2 feet long. I dont plan on getting a whole new exhaust. I just need the last pipe that connects from the muffler to the last flange which is around the back right wheel in the car
The problem is that one pipe doesn't exist because the muffler and that pipe are all one piece hence the response you got from Dweet. If you just want it repaired you are probably best to go to an exhaust shop and ask them to repair it. They will come up with the best solution.
that's how it is on all cars. have you ever seen a car where the muffler is connected by flanges? no. it's always welded on. mufflers are welded to the current exhaust, they aren't bolted on with flanges.
anyway...
the part you're talking about is the axle back part, correct? it goes over the passenger axle, and to the rear bumper. hence the term, axle back. get it?
why would you want to buy an OEM exhaust part from the dealer? that would just be stupid, expensive, and ... stupid.
now, if you're trying to do this on a budget, you can get it fixed at any muffler shop for cheap. they will bend some pipe and re-weld your muffler on. i can't see this costing more than $50.
but, if i were you, i would just buy a cat-back system. increase performance. unless you don't have the money.
good luck.
anyway...
good luck.
