ECU
Old Jun 18, 2011 | 03:37 PM
mustard's Avatar
Vehicle: 1997 hyundai coupe
Default ECU
Hello
i will be doing a rebuild on my gen 1, skimming and porting the head, large air filter, 252 lift cams and a tubular manifold and performance system. do you think the standard ECU would be ok? if not any recommendations?.
Thanks
Old Jun 18, 2011 | 04:05 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
Will it run, probably. Will you actually see decent gains, probably not. If you want to maximize the power out of those mods your going to need to tweak those crap stock fuel/spark maps if possible.
Old Jun 19, 2011 | 02:02 AM
mustard's Avatar
cheers for the reply but what tweaks to the fuel/map will i need to do to get the best out of the mods
Old Jun 19, 2011 | 08:22 AM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
That depends on what hyundai did with your stock stuff. You would need a wideband to see whats going on with the air/fuel mix and a dyno to see if you could gain any power from tweaking the timing.
