Dome Light Problems
Hey guys,
Having some problems with my dome lights. When I got the car one of the dome lights was out so I bought a new light and it worked for about a week then died out. I thought that I bought a dud so I got another one and then It happened again. Not to long after, the other one died. Not even a new light works. Whats going on? Any advice
My only guess is check your fuse box near the feet of the driver side inside the car. See if any are blown, could be your problem. Also, only other thing i could think of is, are you getting to big (amp wise) lights?
If fuses are okay then im stumped.
yea i figure the lights where long shot but best to ask tongue.gif.
Check the fuses.
Another thing is, do you know if the dome setup was aftermarket by this I mean wasn't factory installed.
What I'm getting at is possible wireing problem but check fuses first becuase I could be as simple as a blown fuse!
Check the fuses.
Vehicle: 1997 Tiburon
Okay, open your door, right on the side of the door jam ( near the back rest of your seat, not the front door jam) you will see a little but tall black rubber button. That is what makes your light shut off when your door is shut and what makes your light go on when the door is opened.
Make sure you have a good bulb in the dome light and press that button with your fingure. If the light doesnt come on at all ( you have to push than release, try pulling a bit aswell ) than take the little boot off and have a look in there. Sometimes you migh need to check the connection there or lube it up.
^^^ He should also be able to hit the switch for the dome light and have them come on wether the door is open or not.
I've been having problems with mine also. The wires leading directly to the lights are shorting out. I believe they get sliced between the dome lamp assembly and the roof. Pull the assembly off and check the wires. Move them around, make sure they're still attached.
Vehicle: 2001 Hyundai tiburon
Mine has been doing this for years and it isn't any fuse or button or anything..its just the wireing that goes bad. I had one placed under warrenty and now mynew one is no good...its just a piece of crap
I just got my tib about three months ago and when I bought it the passenger side light was out. So I replaced it and it went out in about a week. Since then I havent replaced it though. Is this a tiburon problem?
