Car wont turn off
Old Aug 26, 2004 | 02:00 PM
Dweet's Avatar
Default Re: Wont start... *sigh*
Well I got the elantra running and its purring like a kitten even without the base timing set. And well my only problem left is when i take the key out the car wont stop.. lol any suggestions?
Old Aug 26, 2004 | 02:04 PM
Hobgoblin's Avatar
Vehicle: 2015 Subaru WRX
Dang doode,
I cant start, you cant stop... We cant win!! LOL :roll:
Old Aug 26, 2004 | 02:52 PM
Cuervo79's Avatar
Vehicle: 2010 Genesis Turbo
Default Re: Official Bush vs. Kerry Thread
um.. woah hehehe. that sounds weird, you've got a spirited car hehehehe, it will turn of when it wants to hehehe lol.gif
Old Aug 26, 2004 | 03:28 PM
Default Front Lip
if you remove the cables from the battery terminals and it keeps running... I would assume it's demon possessed and drive it off a cliff.. preferrably without you in it.
Old Aug 26, 2004 | 03:53 PM
MADTIB's Avatar
Default Re: THE Hobgoblin
Once any car is running you can pull the battery off and it'll still run,cause at that point electrical loads are being supplied by the alternator.
If the car won't stop, it seems like it should be a problem with the ignition system,right? Maybe the key switch has some bad contacts.At any rate,I'd think of things between the key switch and the starter.
Old Aug 26, 2004 | 04:05 PM
x7xstring's Avatar
Default Re: Front Lip
pull the ignition wires quick!!, LOL
Old Aug 26, 2004 | 06:37 PM
Sparticus's Avatar
Vehicle: 97 Tiburon
Default Re: FS: Custom COLORED Shift Boots!
very good chance it's your ignition switch. pull the fuel pump fuse to temporarily get it shut off (i'm sure you're like in the process, or have already fixed it...)
Old Aug 26, 2004 | 06:51 PM
Dweet's Avatar
Default Re: Car Alarm Query
i was talking to some other people and well, one guy said my fuel pump isnt wired into the MPI relay properly, so i'll tackle that sometime soon
Old Aug 28, 2004 | 11:36 AM
zoned019's Avatar
Vehicle: 97 Tib
Default Re: I ran over a...
so did you just let it idle until it ran out of gas or what
Old Aug 28, 2004 | 01:51 PM
Default Re: Cigarette Lighter not working.
