Car Wont Crank
Old Jun 25, 2007 | 09:02 AM
did u get a chance to look at it?
Old Jun 25, 2007 | 11:07 AM
no not yet. ive been getting killed with work and school. tonight or tomorrow hopefully
Old Jun 25, 2007 | 11:19 AM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
<div class='quotetop'>QUOTE (Patreezy @ Jun 22 2007, 10:44 PM) <{POST_SNAPBACK}></div><div class='quotemain'>In the meantime, all I can suggest is to borrow some of radu_RD2's spark plugs. Apparently they magically arc without a voltage supplied to them. There magic alone should be enough to get the tib cranking again!</div>
Old Jun 25, 2007 | 11:47 PM
<div class='quotetop'>QUOTE (Ericy321 @ Jun 25 2007, 01:07 PM) <{POST_SNAPBACK}></div><div class='quotemain'>no not yet. ive been getting killed with work and school. tonight or tomorrow hopefully</div>
Seriously, go and check the pink and blue fusable links in the engine compartment. They're fuses that you can see into. I'm almost positive that is the problem. It's a quick check and then you'll most likely have you car back, unless there's another problem at play. Because you said there was a problem with the power windows, most likely, you're not getting power to the ignition switch. There's only a few wires and a fuse that would cause that. There may be something else causing that fuse to blow though.
