Car Overheating Help
Old Nov 28, 2006 | 08:31 AM
Petrafire's Avatar
Hey,
well for some reason when im driving my car will be running really good then all of a sudden the temp gauge will shoot staight up, my lights will go dim, and my heat will stop working then i will hear a squeeling sound, i will pull over and watch as all my engine coolant gets sucked away to somewhere
what could this be?
Old Nov 28, 2006 | 08:38 AM
water pump. it has a weep hole and is probly draining coolant.
Old Nov 28, 2006 | 01:47 PM
definetly the waterpump
Old Nov 28, 2006 | 03:03 PM
shimanomtber87's Avatar
From: York. About 2hrs from Philly and 4 hours from Pittsburgh
^^^ Yep, happened to me about a month after i got my car....been fine since
Old Nov 28, 2006 | 05:12 PM
replace your timing belt while you're at it.
Old Nov 28, 2006 | 07:31 PM
<div class='quotetop'>QUOTE </div><div class='quotemain'>water pump. it has a weep hole and is probly draining coolant.</div>
yep. you'll find coolant on the ground under your car. i think Kspec has the waterpump maintenance & replacement kit with belts. that was happening to me. you can drive the car short distances, but i drove 1000 miles to florida and broke down on a VERY overheated engine. man... my engine was so hot you could boil eggs on the valve cover. cost me $1500 in damages.
i learned my lesson on car maintenance. we all do at some point.
Old Nov 29, 2006 | 01:38 AM
Petrafire's Avatar
is this water pump and timing belt easy to do myself or should i get the garage to do it?
Old Nov 29, 2006 | 07:15 AM
I never did the waterpump (when I changed by t-belt, I bought a waterpump to change it too, but the wrong pump was in the box and I did not discover it until I had the car apart) but the timing belt can be a pain in the arse. If you do not feel confident about working on the engine or your car, find somebody who can do it for you
