Can I Get A Wtf?
Old Sep 7, 2005 | 05:34 PM
tanc's Avatar
Vehicle: 1997 Tiburon
1. Well I bought an OEM fuel filter from the dealership around here, and when I started dissassembling mine, I noticed the tops are different. I checked part numbers and the numbers matched.WTF?
The new filter as you can see has a hexagone 19mm. The old one doesnt. And the base is round. In my shop manual it shows my exact setup I have on the car, but when I searched I read people had the hex on top. I'm confused...
2. I can't for the life of me take the bottom fuel line off. It's a tight sqeeze and I can't even seem to budge it. I even called my old man over to give me a hand.
Old Sep 7, 2005 | 05:38 PM
tibbytib's Avatar
I remember when I did mine, the bottom fuel line was a b**** to get off. not sure what to tell you about the filter. I got mine from Checker Auto Parts. Worked like a charm. Good luck with it! fing02.gif
Old Sep 7, 2005 | 05:40 PM
long's Avatar
i was just looking at that shit in the manual like 10 min ago.
i have a new filter and didnt even notice the differnce until you just pointed it out.
i was going to install mine tommorrow.
that is crazy. lemme see if i can find out
Old Sep 7, 2005 | 07:15 PM
tanc's Avatar
Anyone else have any input?
I'm sure some of you guys must of did your own Fuel Filter tongue.gif ....lazy bast**ds owned.gif
Old Sep 7, 2005 | 08:24 PM
holy crap was it a pain in the ass. i ended up stripping the bottom nut, so i had to use some vise grips and put all the muscle i got into the thing to keep it from leeking.
some have said its easy if you get a flared wrench. its like the closed end of the wrench, with a bit cut out of it to get it around say, wires or tubing.
Old Sep 7, 2005 | 09:58 PM
flair or Line wrench is indispensible when working fuel or brake lines.
And I cannot say I have ever changed by fuel filter... 112,000 miles and going strong.. heh, I can be a lazy bastard sometimes.
Old Sep 7, 2005 | 10:07 PM
tanc's Avatar
Flared wrench, I will give that a shot but what about the top of the fuel filter. It's not the same.
Old Sep 7, 2005 | 10:20 PM
well, you need to get a different filter if its not the right one. mine was correct.
Old Sep 8, 2005 | 03:53 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
I use the same fuel filter as you posted.
I changed already 2 of them wit hno problem
Old Sep 8, 2005 | 06:42 AM
rallyman's Avatar
The hex nut that you are showing on the new one points down when it is installed. Show us a pic of the other end of the new filter. It should look the same as the one on your car with a hole for the fuel line and one for the bolt.
