Can anyone identify this plug?
Old Jan 6, 2005 | 10:06 PM
fonseca's Avatar
Default Re: exhaust sound clips
I came across this today while installing Fatmat. This plug comes off the wires that end up at the passenger side rear speaker. There doesn't appear to be anything to plug it into? Am I missing something? I'm guessing this must be for an option I don't have...
And on an unrelated note, I am about to replace the door lock actuator on the driver's side, which is making strange noises. If I install one on the passenger side door, will that unlock the driver's door at the same time? As it stands now only the driver's side door has an actuator, and unlocks both doors. I think that should work.
Edit: the door lock schematic on webtech shows a left door lock actuator installed, but my passenger door only can receive, not send. Hmm. I'm not sure this will work.
Old Jan 6, 2005 | 10:16 PM
Kit-Fox's Avatar
Default Re: Tim i sent you a PM.. look here
maybe umm a rear wiper.
P.S. this deals with the topic due to the fact that i am trying to help a person in explaining a possibility for an extra wqire, i belive in using logic that if he dosent have a rear wiper there may be the possibility of the wire being intended for the use but not having a after stock wiper later on but still having the wiring system
Old Jan 6, 2005 | 10:35 PM
MAXXTIB's Avatar
Default Re: 2 questions
To many wires to be for a rear wiper, does your car have ABS, I think thats where they put the ABS computer.
Old Jan 6, 2005 | 11:24 PM
fonseca's Avatar
No ABS, maybe that's what it is. I'm guessing that upgrading to ABS would be very involved...not even gonna think about it.
Old Jan 7, 2005 | 10:08 AM
Blu_Drgn's Avatar
From: Lillington, NC & Maryville, TN when I can get there
Default Re: Spiderman? Anyone like Kiersten Dunst?
Why would you want to upgrade to ABS that shizz sucks
Old Jan 7, 2005 | 12:32 PM
fonseca's Avatar
Default Racing Hart CX multi piece wheels. Yay or nay?
Probably for the same reason I'd like to "upgrade" to a rear windshield wiper, factory fogs, heated seats, etc. Just because it's possible. Not that I really need or particularly desire ABS, and it meant more maintenance on my last car, but a good ABS system can result in much more control in some situations no matter how good you think you can brake without it.
