Break Booster Line
Old Aug 2, 2005 | 08:01 PM
zoned019's Avatar
Vehicle: 97 Tib
yeah, they both say to add it right to the crank, then start the car and let it idle, then drain/change oil/filters.
Old Aug 2, 2005 | 08:08 PM
fonseca's Avatar
How often do all of you do this?
I just used a fuel system cleaner added to the gas tank. That's supposed to clean the valves and injectors, but this sounds like a more thorough solution.
Old Aug 3, 2005 | 01:05 AM
H3NDR1X15's Avatar
You shouldn't do it to often. It puts a strain on your gaskets and seals. Its meant to be used only when needed. My car has about 110,000 miles on it so I figured there would be a little build up of junk inside it. I wouldn't use it any more than every 50,000 miles.
