Beta Supercharger
Old 07-02-2015, 11:30 AM
PaTuners's Avatar
Originally Posted by 03tibe85
I agree with pretty much what everyone has already said. I also tried the twin set up with both a MP45 and M62 on the Beta II engine. Was a NIGHTMARE to tune and traction was none existent all the way through 2nd gear and most of 3rd. Plus you MUST have a built block to even think about twincharging.
If your block is built and you want to be different think about sequential turbocharging. Get a small turbo for low end and a biggun for the top end.
yes it is built and I am trying to be different so Im going to look into the sequential turbocharging. Thanks for the input I appreciate it.
Old 07-02-2015, 12:09 PM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
It will be as struggle to get to 200whp with the MP45. Problem is if you could find a pulley to generate enough boost you'd have no way to deal with all the heat the blower makes at the higher boost levels. You could run meth but that will quickly ruin the rotors and bearings.
Old 07-02-2015, 12:31 PM
PaTuners's Avatar
Ok Guys Thanks for all the advice Im going to stick with turbo setups in all my cars.
Old 07-02-2015, 01:14 PM
PaTuners's Avatar
what kind of whp numbers you guys get out of the mp45?
Old 07-02-2015, 01:19 PM
03tibe85's Avatar
Best I've seen is in the 180-190whp range at 10-12psi. What really kills power is really no way to inter cool it. Adding more pressure just adds heat which kills power.
Old 07-11-2015, 10:57 AM
PaTuners's Avatar
I have been told by the guy with the sc that wastegate sc so you can run a boost controller on it to adjust boost I thought you had to change crank pulley. help guys please
Old 07-11-2015, 11:49 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
No such thing as a wastegate s/c. Most do have bypass valves, but those are only there to bypass the s/c when the engine is idling. You can run meth with a s/c, but the proper way is to use a jet on each intake runner, after the s/c.
Old 07-11-2015, 01:46 PM
PaTuners's Avatar
so I would need to find the pulleys to up the boost
Old 07-12-2015, 12:25 AM
PaTuners's Avatar
did they make many beta sc kits
Old 07-12-2015, 12:41 PM
No, because this application is SO much better suited to turbocharging. Most of the kits I've seen recently involved adapting parts made for other cars.
