Best Headlight bulb replacement ?
Hello everyone,
I was wondering if any of you had a Good replacement bulb for high beams you could recommend ? OR,,,Have any of you ever used the Philips Rally H1 12V 100W in a 01 Tiburon ? I wanted to try this one , But Don't know how the lense (stock Plastic I assume ?) will deal with the heat ? I live out in some Major Rural area,, Great Windy roads,,It's pretty much Farm land with Amish and Buggies, Horses,,and LOTS of Deer!! LOL I do a Lot of Driving at night and want as Much Light as Possible when I Click on the High Beams. I Figured Something like this Philips Rally H1 12V 100W would be the ticket ?? Any Advice from experience would be Greatly Appreciated. Thanks For your time and Consideration , Sincerely Desode |
Get HIDs. They are inexpensive these days, produce the most light, and last longer and won't burn out your harness trying to use a 100 watt bulb.
HIDs for low beam, but putting HIDs in a standard halogen reflector housing actually kills baby unicorns.
:1:
35W HIDs are all you'll ever need and light up the road like you wouldn't believe. IIRC 55Ws have caused heat problems, so keep with 35s and you'll be good. I got mine here: http://www.ddmtuning.com/Products/DD...ast-35W-or-55W They've been great and weren't a whole lot more than a good set of bulbs. Install was quick too. Just keep with a reasonable color temp (white or close) or the quality of light will suffer. |
I agree on HIDs. Either 4500k or 6000k or somewhere in between.
