BBTB
Old Sep 19, 2004 | 10:07 PM
col96fx's Avatar
Vehicle: Hyosung GT650
Default Re: My new whip
So is that the most the engine can handle :?:
Old Sep 20, 2004 | 05:25 AM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Default Re: Wheel Spacer?
I think it's the biggest you can go because after that you cannot generate as much power. The engine simply cannot suck in enough air to make power.
Old Sep 20, 2004 | 05:29 AM
Default Re: Which size Optima battery?
<div class='quotetop'>QUOTE (col96fx)</div><div class='quotemain'>So is that the most the engine can handle :?:</div>
I agree with Silvertibs...
I think you'd start to feel a drop in power if it sucked in too much air... either way, you'd definitely need a fuel regulator of some sort...
Old Sep 20, 2004 | 09:09 AM
Voiddweller's Avatar
Default Re: Sounding different
The thing you have to be careful of is running lean which can lead to detonation and end up blowing your engine.
Old Sep 20, 2004 | 10:08 AM
CyberShark's Avatar
Default Re: BBTB
62mm is the most you can go with N/A..you can use a larger throttle body for turbo..especially if you have a turbo with an AirRam setup. In that instance, you could go between a 67mm to a 70mm (if you enlarge the AirRam opening)..I believe that's why Redz was asking if you could make a 70mm.
Old Sep 20, 2004 | 11:00 AM
Dweet's Avatar
Default Re: I'm back photoshoot.
<div class='quotetop'>QUOTE (Voiddweller)</div><div class='quotemain'>The thing you have to be careful of is running lean which can lead to detonation and end up blowing your engine.</div>
i really dont see you running lean with this setup. Our injectors can handle the extra air and our ECU's run as rich as it is.
Old Sep 20, 2004 | 11:30 AM
Default Re: BBTB
Alright, so in summary we can run as high as 62mm bore on our throttle bodies without running lean/losing power. Anything higher than that may require a little bit of tuning and it would be a better way to go for a turbo setup.
:? wink.gif
Old Sep 20, 2004 | 12:13 PM
CyberShark's Avatar
Default Re: Exhaust Help
Yep..that about sums it up.
Old Sep 20, 2004 | 02:01 PM
LarryMcFly's Avatar
You can't bore your stock tb to 62mm, max is 58mm. If you want more than 58mm, you need to change the tb.
Old Sep 20, 2004 | 11:20 PM
Default Re: pics
<div class='quotetop'>QUOTE (LarryMcFly)</div><div class='quotemain'>You can't bore your stock tb to 62mm, max is 58mm. If you want more than 58mm, you need to change the tb.</div>
No one said to try boring the stock TB to 62.
