ab-b Hyundai recalls over 419k vehicles in three campaigns
Vehicle: Hyundai
Filed under: Sedan, SUV, Recalls, Crossover, Hyundai
General Motors is the undisputed king of recalls for 2014. No one is going to contest this point. The American company is far from the only one with vehicles that need fixing, though, as Hyundai has announced another recall totaling 419,000 vehicles in three separate campaigns.
The majority of the vehicles affected come from the Santa Fe family, where 225,000 of the model year 2001 to 2006 CUVs will need their front springs replaced. It seems that the early Santa Fe's coils can rust and crack when subjected to frosty temperatures and the road salt that so often accompanies them. Should they fracture, it's possible that a crash would be the end result.
As this is an issue linked to road salt, only Santa Fes sold in 20 states - from Maine to Iowa and Wisconsin to West Virginia - are affected. Vehicles sold in Washington, D.C. are also covered in the recall.
Meanwhile, the Sonata sedan is getting dinged with another recall, the nameplate's third in less than three weeks. This time, the 2011 model is at fault, with 133,075 vehicles that could be leaking brake fluid, thanks to a bad seal between brake hose and the brake-line fitting.
Finally, the Veracruz is facing a recall, with 61,122 of the SUVs suffering from potential alternator failure. This issue is caused by a bad valve cover gasket in the front cylinder bank, which could cause oil to leak on the alternator causing the vehicle to stall or refuse to start.
None of these issues have lead to any crashes or injuries, although the Santa Fe's spring issue has resulted in 1,200 warranty claims and 90 cases of the spring contacting the tire, according to the Associated Press. As is usually the case, repairs on each vehicle will be conducted free of charge, while Hyundai plans to have notified owners of all affected cars and SUVs by the end of September.
Scroll down for the trio of bulletins from the National Highway Traffic Safety Administration.Continue reading Hyundai recalls over 419k vehicles in three campaigns
Hyundai recalls over 419k vehicles in three campaigns originally appeared on Autoblog on Fri, 01 Aug 2014 16:29:00 EST. Please see our terms for use of feeds.
Permalink | Email this | Comments
View the full article
