Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
why wont it start...
Old Sep 23, 2012 | 05:12 PM
98x3beta's Avatar
Vehicle: 1998/Hyundai/accent
Default why wont it start...
I have a 98 accent with beta 1 swap. I've had the car put for about 4 weeks now. And I haven't put the mount until today. But right after I finished the mount the car wouldn't start..the car was just driving fine lastnight. So I don't understand but it cranks strong. It will crank over for less then a second then turn right off.please. help if u have any idea thanks.
Out**
Old Sep 23, 2012 | 08:59 PM
Old Sep 24, 2012 | 06:27 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
last time that happened to my car it turned out to be the wizzle wuzzle. $5 at the dealership installed.
Old Sep 24, 2012 | 07:06 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
You installed a motor mount?? and the car doesn't start? Simplest answer being the correct answer, you unplugged an important sensor/system. Go back over the area you were tinkering in.
Old Sep 24, 2012 | 09:09 PM
98x3beta's Avatar
It sounds crazy. Lol but this is what's happening. I looked for anything that could've been moved there's no wires there. But all day I've changed crank senser. Cam sencer alternator and battery. And today when I would jump the car. The car turned on fine. And ran then when I took the cables off the car died..... I have no clue.... I even changed fuses. Ex alternator fuse. Im having trouble getting it out.??
Old Sep 24, 2012 | 09:11 PM
98x3beta's Avatar
Old Sep 25, 2012 | 08:33 PM
Please refrain from making multiple threads for the same problem. The other thread on this topic is here: https://www.hyundaiaftermarket.org/f...47#entry669147
