My beta swapped accent 4 door soon to be alpine supercharged
I just finished my beta swap on my 01 Hyundai accent gl
03 tiburon engine act clutch 02 elantra trans accent shift cables, clutch master cylinder, clutch pedal, brake pedal 03 tiburon flywheel bolts (6) Chase bays clutch line Redline Gl4 75w90 gear fluid fidanza flywheel Ark lightweight pulleys K040335 (34” or 860MM) for the Water pump and alternator belt. obx intake manifold thermal heat gasket 1.8 elantra pass axle automatic Timing belt Gates. toga main and rod bearings toga hv oil pump water pump Bosch felpro headgasket kit ngk Sparkplugs and wires arp head studs arp main studs elantra Bosch starter alpine supercharger kit 190 lph walbro fuel pump 440cc injectors wrx aem ems 4 + harness snow Methanol injection kit Megan 4-1 header w/dei heat wrap Twm short shifter, knob & bushings qtp electronic exhaust cut out 2.5" jmf oil catch can Jmf coolant reservoir Jmf small battery kit megan m-oe muffler magnetic drain plug Aem intake Its not meant to be a race car just a fun dd that i actually enjoy driving Here's a pic with the coolant reservoir and catch can, keep in mind I just got it running its still a work in progress http://i53.photobucket.com/albums/g6...ps61506f52.jpg |
sickly sweet project man!! looking forward to your progress..i hope you can achieve more than what most of us fellow former beta-swapped guys couldn't.
This sounds like a really, really sweet project. I always toyed with the idea of a supercharged beta in an accent. Put on stock front tires and fry third with no fucks to give.
Nice swap!:thumbup:
switch back to the oem crank pulley-... lightweight crank pulley and boost seem to blow up oil pumps
Originally Posted by 01steve
(Post 683784)
I agree, I blew a couple... |
aka..harmonic balancer.
sometimes oem parts are the way to go for reliability and durability. |
also, those 440s are a bit overkill for the alpine but should work ok
a lightweight, near instant torque, accent sounds pretty fun, but dont expect to win any drag races with it :cool: |
:thumbup: The Alpine S/C's are EXTREMELY rare. Way awesome that you have one in working order AND a beta swapped accent. Did you make custom engine mounts?
it's rare to see a blown accent cruisin the streets...with the meowing of the supercharger and that big lump of useable power at your disposal..might as well call it the beta accent 2.4L
given the fact that roots type blower excel's at low end but not high end torque..but meh..it's not everyday we get to see a member belt boosting a accent.. it's probably the best news i heard in years |
| All times are GMT -6. The time now is 02:10 AM. |
