megasquirt v3 install complete...plus a question...
Vehicle: 2005 Hyundai Accent
hey, Just wanted to say I finished my megasquirt install on my beta2 accent. Runs real good with only a couple days of tuning on it. I have one question though to anyone who has done a megasquirt install. What did you do for the canister purge valve? right now I just have the hose venting to the atmosphere all the time? thanks.
i suppose you could run it back into the IM, it'd just make the car run rather rich for a minute or two, then go back to normal. if you are running on open loop, perhaps make the computer revert to closed loop while the canister does its thang. hell, you could even run a bonus lean map to compensate for the momentary richness.
yeah well the valve normally runs back into the Intake Manifold but for now Im not sure when exactly the canister is supposed to vent, so I use that existing vacuum for my map. I will have to see when it is supposed to be on or off and program an output for it. The valve broke when I had my 1.6 and i drove it without noticing anything for almost a year so I figured I would let it vent to atmosphere until I could figure out when to run it. Im guessing it will affect the tuning somewhat.
Venting to atmostphere wont do anything. It works off of vacuum, when it opens, vacuum from the engine will suck the gasses out of the canister. Just leave it alone,unless emmisions are a problem then hook it up. It comes on at idle or under high vacuum conditions like decel so techincally you can hook it up when MS goes into overun, very low KPA.
Did you run full standalone on that Beta motor? I want to know how you got your cranking signal. What are your settings in MS?
Hey fastest, I just got your .msq from your link along with the other turbo Tib. So you hooked up directly to the CKP and the cam sensor as a secondary or just the ckp that's on the front of the block? SOrry for the thread hi-jack.
Yes I am. I still use the factory coolant temp sensor. The factory coolant sensor actually seems more accurate. they are both close enough to tune and run the car with.
