lc with beta2 don't start
Vehicle: accent 2001
I swap my lc with a beta2 motor and trans, i keep the ecu from lc.
i change crank sensor, coil pack, extend the wire for the tps
the car don't make nothing,just running on starter
i check the crank sensor and have no 12v
So please help me to start my car, my wife is not happy to past is car every day
thanks
Simon
thanks
Simon
Vehicle: 02 Hyundai Accent
Re pin the accent harness to work with the elantra ecm. I used to have the Elantra harness in my car but there is a large amount of hacking and soldering wires back together. I found re pinning the harness to be a bit easier. Take a look here https://www.hyundaiaftermarket.org/f...-pinout-guide/
I noticed you said you dont have 12v at the crank sensor and if your using the alpha crank sensor then you shouldnt have a 12v wire there at all.
The harness on LC 1.5 and 1.6L are not the same, but they are close. For instance the coolant temp sensor plug is not on the 1.5L harness at all were it does exist on the 1.6L harness, 1.6L harness has a MAP plug and the 1.5L has a MAF. Of course this would be U.S. spec accents im talking about. I dont have any knowledge on how oversee accents are wired.
