Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
LC beta swap 1.5 Trans mount
Old Mar 25, 2011 | 09:49 AM
bobyback's Avatar
Vehicle: accent
Default LC beta swap 1.5 Trans mount
I have a quick question
I will use:
BETA 2
1.5 LC transaxle
Accent X3 driver axle
BETA 1 Passenger engine mount.
What would you recommand for the 3 other mount?
Drilling 1/4 distance each hole to move everyting to the driver side? since im using 1.5 Transaxle i need some advide.
Old Mar 25, 2011 | 09:56 AM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
OEM!!
Old Mar 25, 2011 | 10:00 AM
bobyback's Avatar
Vehicle: accent
Originally Posted by Juanra
OEM!!
yes i will use oem but i need to move everyting a little bit to let some space on the passager side
Old Mar 25, 2011 | 10:02 AM
Juanra's Avatar
At least for the X3 I didn't have to move the engine...
Old Mar 25, 2011 | 10:11 AM
bobyback's Avatar
Vehicle: accent
same here i have a X3 2.0 too...
BuT in a LC there is less space
Old Mar 25, 2011 | 10:13 AM
Juanra's Avatar
Ohhh I always thought that was the opposite...
Old Mar 25, 2011 | 10:28 AM
The holes on my mount might be slotted, but it's the OEM 1.5l mount.
Old Mar 25, 2011 | 11:12 AM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
I slotted the 3 transmission mount brackets 1/4 inch, beating down the inner fender wall was not an option I wanted to take. Then I fabricated a driver side mount, someone else welded for me. Using the 1.5L manual you will need to notch out a portion of the beta block for the slave cylinder that mounts to the mating surface of the trans. Also there is some changes needed to the flywheel/clutch but I dont remember what it is, I used the beta 2 trans.
Old Mar 25, 2011 | 11:14 AM
HotBlue02's Avatar
Oh and I used the 1.5L mounts and brackets on the trans, there nearly identical down to the mounting points.
