Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Jsharptooth91's Beta 2 swap
Old Oct 15, 2008 | 02:47 PM
  #81
slyderdai's Avatar
<div class='quotetop'>QUOTE(jsharptooth91 @ Oct 15 2008, 02:43 PM) </div><div class='quotemain'>It seems on cold mourning the car hesitates to start up. But, it does start. When I turn it over it turns over then bogs down and then goes to normal idle. This all happens in about 5 secs. Only on cold mornings. Any ideals on what this could be?</div>
No Idea! My Elantra has done that since day 1. I just figured it was a normal thing.
Old Oct 15, 2008 | 04:34 PM
  #82
cclngthr's Avatar
Vehicle: 2007 Hyundai Elantra SE
<div class='quotetop'>QUOTE(jsharptooth91 @ Oct 15 2008, 11:43 AM) </div><div class='quotemain'>It seems on cold mourning the car hesitates to start up. But, it does start. When I turn it over it turns over then bogs down and then goes to normal idle. This all happens in about 5 secs. Only on cold mornings. Any ideals on what this could be?</div>
You might have a problem with a sensor or a fuel/spark issue at startup. It sounds as the ecu thinks there is a possible timing issue. Recheck your wiring on all sensors, coil packs and doublecheck the fuel system.
Old Oct 15, 2008 | 04:38 PM
  #83
Could be a fuel leak making the pump run for a bit before it'll have enough pressure to fire.
You could check that by turning the key on a couple times so the fuel pump will prime before you hit start.
Old Oct 15, 2008 | 07:38 PM
  #84
jsharptooth91's Avatar
Vehicle: 2002 Accent 2.0L
I will check it out.
I have another question. When I burn rubber sometimes, its like my hole front end bounces up and down, its almost like the car is going up and hitting the ground, its sounds really bad. Is their anything I can do about this?
Old Oct 15, 2008 | 07:56 PM
  #85
slyderdai's Avatar
<div class='quotetop'>QUOTE(jsharptooth91 @ Oct 15 2008, 09:38 PM) </div><div class='quotemain'>I will check it out.
I have another question. When I burn rubber sometimes, its like my hole front end bounces up and down, its almost like the car is going up and hitting the ground, its sounds really bad. Is their anything I can do about this?</div>
Solid Motor Mounts! It's called Wheel Hop. You should have done the Urethane DIY mounts before hand(as I am right now)
As for the cold start Issue? I have had the same thing for Over 50k now. I have a CEL from my O2 sensors not being hooked up but those are the only codes I'm throwing.
J do you have any CEL lights or COdes showing?
Old Oct 15, 2008 | 10:10 PM
  #86
Solid motor mounts, stiffer springs, struts with better dampening, KFX lower brace, strut tower brace, engine dampener, SFR fender brace
All those could help. Poly mounts, better struts, and engine dampener would probably help the most.
Old Oct 16, 2008 | 11:33 AM
  #87
No cel or anything. Yesterday, the cel flashed at me, saying that is a misfire. but it was running great. Maybe the shaking was casing the car to think that it was miss firing.
I was thinking about doing some solid mounts, but I dont want the motor to shake the car to much.
Old Oct 16, 2008 | 11:37 AM
  #88
wilburisthecoolest's Avatar
Vehicle: 1997 Elantra(Dead project) 1986 Golf(Track whore) 2000 Ranger(Daily)
<div class='quotetop'>QUOTE(jsharptooth91 @ Oct 16 2008, 10:33 AM) </div><div class='quotemain'>No cel or anything. Yesterday, the cel flashed at me, saying that is a misfire. but it was running great. Maybe the shaking was casing the car to think that it was miss firing.</div>
It will do that. Do you have the rough road sensor?
Old Oct 16, 2008 | 11:43 AM
  #89
I'm not sure off the top off my head. I know their is a knock sensor and an accelerator sensor. I think
Old Oct 16, 2008 | 10:48 PM
  #90
ravinaziankid's Avatar
Vehicle: 2002 Beta Hyundai Accent
Are you using a Manual Transmission ECU? I am getting a CEL for missing transmission and wanted to know if you're using a manual ECU to maybe help clarify if that's my problem.
