I test fired my car...
#31
1 Post
Vehicle: 02 Hyundai Accent
Ok here is the video, anyone recognize that tick from my engine, sounds like top end to me. How easy is it to adjust valves if thats what it is?
http://smg.photobucket.com/albums/v6...t=100_5436.mp4
#34
1 Post
hmmm, oil change was done only a month ago, sounds simular to the bad rod bearing I had back in may, just not nearly as loud or nasty. The cylinder head has 150K of some hard high rpm miles on it and has been through a number of overheating situations and 1 oil starvation that took out the last block.
#35
Vehicle: 2005 Hyundai Accent
very nice work. Does your motor rub the hood? I have home made polyurethane bushings all round and had to bang the heck outta my hood to get it to close and shimmed the back up 1/8 of an inch. The hood shakes violently at idle and still rubs a bit. Im just waiting to make a custom fiberglass hood and scoupe one of these long days.
#37
D: ruh row - mine is making a VERY similar noise. in my case it seems to be coming from the water pump, so i'm pulling the motor asap to have a look. a good way to find the source of the noise is to put your ear to the handle of a screwdriver, then touch it in places around the noise. it basically becomes a stethoscope.
#38
Vehicle: 1997 RD 4-door
I will be updating the pinout guide some time this week but so far so good. I still dont know whats up with my fuel gauge being off but now i know at full it should be at 33 ohms and empty at 240 ohms so I can test the sender an see if the problems there.
Floyd did Tak use the 1.6L harness?
yes, my car originally has the 1.6l alpha II harness, along with the 1.6l ecu, the car doesn't have enough low end torque but passing power is amazing,
#39
i've been contemplating to mod the beta to milk out more power, like with 1.8l cams and installing a beta ecu,
its 1.6l ecu still is sealing the betas true power,
