Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
How much does the a beta swap mess up the suspension?
Old Mar 1, 2010 | 10:25 AM
accent718's Avatar
Vehicle: 2002 Hyundai Accent
Default How much does the a beta swap mess up the suspension?
Those of you who have done the beta swap, how did it mess up your suspension? Our suspensions are rated for a certain weight. By adding a beta engine and transmission, the car becomes heavier. Im sure the stock suspension takes a hit from this so what did you do to upgrade your springs and struts? Even aftermarket springs and struts are designed to handle a stock accents weight so im wondering how you all upgraded without any problems.
Old Mar 1, 2010 | 11:15 AM
JonGTR's Avatar
What is the weight difference? Like 40lbs maybe? Just swap your battery for an Odyssey PC680 and you just cancelled it out.
Old Mar 1, 2010 | 12:06 PM
Weight difference is 63 lbs. 317lbs vs 254lbs.
It's about the same weight difference as having a full tank of gas or a nearly empty tank. Makes way less difference than having a passenger does.
Old Mar 1, 2010 | 12:58 PM
rooney10's Avatar
Vehicle: 2002 Hyundai Accent GS
I did the beta swap and my suspension is doing just fine. 1.6 inch drop B&G springs and kyb's.
