Hyundai Hybrids Want to drop in a Beta for your Hyundai Accent? How about a 4G63 in your Hyundai Elantra? Maybe a Beta 2 for your Hyundai Tiburon? Post all questions here relating to transmissions and engines from other makes and/or models, you want to install in your Hyundai.
Beta swap axles
Old Sep 28, 2019 | 07:36 AM
Matty.C.93's Avatar
Vehicle: N/A
Default Beta swap axles
Hi all. Looking for info on a beta swap for the x3 Excel (Australian here). I have seen different info on axles for the beta motor/trans swap, from using j1 Lantra axles to using lc(?) Axles. I dont want to get modified axles if i can avoid that. What have you all done, or what axles would work?
Thanks for the help.
Old Sep 30, 2019 | 01:30 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
It depends on the transmision you are going to use.
If you use Alpha tranny you don't change the Axles.
Old Sep 30, 2019 | 07:13 PM
Matty.C.93's Avatar
Vehicle: N/A
Plans are, beta 1 g4gf, beta 1 or 2 transmission. I may have mistaken the axles. I think the accent/lantra thing is if you move the engine over.im not 100% sure if i will do that as of yet.
Old Oct 15, 2019 | 10:21 AM
Juanra's Avatar
The OEM X3 axles will not lock in place in a Beta tranny
Old Oct 23, 2019 | 08:26 AM
Matty.C.93's Avatar
Vehicle: N/A
Okay, have you done the swap and what g/box axle set up have you got. I want a nice cruisable car that isnt going to ring its neck out at 100km/h. So the 3.65 (?) Gearing from the beta gearbox is what im after.
Old Oct 23, 2019 | 09:53 AM
Juanra's Avatar
The option are:
3.65
3.84
4.05
4.29 (rare)
For high speed cruising the best option is 3.65.
Old Jan 17, 2020 | 10:54 AM
gzk's Avatar
gzk
Vehicle: hyundai accent X3 99 gt turbo 1.5 dohc
on my 99 accent x3 with beta engine and beta transmission i use hyundai accent LC 1.5 3 cylindre CRDI axle . axle are bigger and longer one is 2 part with bearing to bolt to your block .so you have 2 axle same length and bigger than tiburon axle !!!
Old Jan 23, 2020 | 11:16 AM
Juanra's Avatar
There are no 3 cylinder Hyundais in the USA.
Old Mar 16, 2020 | 08:43 PM
Matty.C.93's Avatar
Vehicle: N/A
I’m from Australia. I want to know if it’s possible to use Early 2000’s model LC(?) or the J1 Lantra axles with a Beta 1 motor and Beta 1/2 gearbox swap into an X3 Excel.
Related Topics
Thread
Forum
Replies
Last Post
that_fluffy_kid
Hyundai Hybrids
15
Jan 21, 2015 11:30 AM
jninjea
Hyundai Accent Forum
3
Sep 9, 2013 04:06 PM
me_go_fast
6
May 15, 2009 12:52 PM
minorglitch215
3
Oct 15, 2008 11:41 PM
faithofadragon
Engine, Intake, Exhaust
10
Apr 25, 2005 04:59 PM
