skierd |
04-02-2002 12:01 AM |
Well, I'm not so sure the newer (2001+) accents can do the swap w/o a kit. The only year accents that have had this done are the 95-99 model and a 2000 model. The 95-99 models require a kit. The 2.0L basically bolts into a 2000 accent, as much as an engine can "bolt on".
Although the 2000 and the 2001&2002 identical, they are not. The 01/02 models, at least the ones with the 1.6L DOHC have both a returnless fuel system and a subframe. Both of these are gonna make the swap a lot more difficult, becuase the beta (the motor in the tib/elantra) uses a return fuel system. Also, the motors that came from a tib/elantra with a subframe (2001+) will have different mounting points presumably becuase they are bigger than the accent, and the previous cars had a center crossmember to which one of the tranny mounts attaches. I sincerely doubt that crossmemeber would fit on the subframed accent.
Basically, it aint gonna be the easiest thing in the world.... but anything is possible with money. wink
[ April 02, 2002, 08:03 AM: Message edited by: skierd ]
